It is currently Fri Aug 15, 2025 2:18 am
 Post subject: I had never noticed
PostPosted: Sat Jan 03, 2015 10:27 am
Last Name: Colbert
City: Anacortes
I've been doing a little refining of my headstock design, namely adjusting the string line between the nut and the tuners. I don't like how close the A string passes by the E string tuner post. I decided to do a cad drawing of the Martin headstock so I could drag the drawing over the drawing of my current design to compare geometry. What I found was surprised me... Martin moves the E string tuning machines outboard a 1/16" in order to deal with the string line issue. How had I never noticed this?
Anyone else miss this?
Cheers, Michael
These users thanked the author Michaeldc for the post: pdolan (Sun Jan 04, 2015 8:45 pm)
 Post subject: Re: I had never noticed
PostPosted: Sat Jan 03, 2015 10:37 am
Well if you aren't aware of the issue it's one of those things easily missed. Of course if it flared out much more (from the fretboard transition) that would also take care of it. Actually on many Nylon stringed instruments it's fairly common to see the strings foul one of the tuner posts. Matters much less on Nylon strings.
These users thanked the author Michael.N. for the post: Michaeldc (Sat Jan 03, 2015 11:03 am)
PostPosted: Sat Jan 03, 2015 10:45 am
Yeah .. I always hated that look, so I tried to make my Martin style headstock pattern a touch wider ... if you look at Martin, Larrivee, Taylor 12 strings, the strings actually bend around the E string post to get to the A and B ... not my kinda thinking, so mine don't do that ... different headstock shape, more Gibson like ...
These users thanked the author TonyKarol for the post: Michaeldc (Sat Jan 03, 2015 11:03 am)
PostPosted: Sat Jan 03, 2015 11:08 am
First name: David
Last Name: Ferraro
City: Franklin
State: Pennsylvania
Zip/Postal Code: 16323
I only noticed that when inspecting a CNC carved neck from stu-mac, and noticed they weren't linear. Don't know if that's modeled after a martin head or not?
PostPosted: Sat Jan 03, 2015 11:39 am
First name: George
City: Seattle
I hadn't noticed Martin's layout, but I found myself adjusting things similarly when designing my own headstock shapes. I still haven't decided on a final look for mine. Luckily I enjoy experimenting.
George :-)
PostPosted: Sat Jan 03, 2015 12:38 pm
First name: Patrick
Last Name: Hanna
State: Missouri
I never noticed, either, but I don't have many chances to handle Martins. It's a good solution--one that is so subtle it's not likely to be noticed by many people. And it's symmetrical, so it looks nice even to most who notice it.
PostPosted: Sat Jan 03, 2015 1:49 pm
Thanks for pointing that out Michael. I had never noticed. I've never been a fan of their head stock shape. And now that you draw attention to this I like it even less.
I'm surprised by how much I've overlooked this with Martins. Because the tuners / washers relationship to the edge of the headstock is something that drives me crazy in my own building. I look at Olsons and Ryans and notice how they've got that down to a science, and I don't think I've come close even once in a dozen guitars. Part of the reason I put a backing veneer on the headstock is to "cover up" that inconsistency.
These users thanked the author phil for the post: Michaeldc (Sat Jan 03, 2015 3:07 pm)
PostPosted: Sat Jan 03, 2015 2:11 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
That's funny, I noticed on my first guitar, only because I assumed it was one more case where I had screwed up :-)
These users thanked the author JSDenvir for the post: Michaeldc (Sat Jan 03, 2015 3:07 pm)
PostPosted: Sat Jan 03, 2015 3:10 pm
I noticed that problem for sure. Even worse on a 12 string. The larrivees come pretty close but don't actually touch on the 6 strings. The 12 strings are a design fail that I couldn't get changed no way no how.Image
I think on the next one I do I will draw the line outwards by 1mm further each side. They don't touch but are pretty close. They touch on my Martin 12 string.
PostPosted: Sat Jan 03, 2015 4:33 pm
First name: D
Last Name: S
It is quite obvious on a Melody Maker.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Jan 03, 2015 6:39 pm
Last Name: Beaver
City: Lake Forest
I take the easy way out....
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: jack (Sat Jan 03, 2015 7:00 pm)
PostPosted: Sat Jan 03, 2015 7:17 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Nice, Joe. Many others are doing something similar, as you know very well. But it's still interesting about Martins. I suppose that headstock shape evolved out of an historic slotted head shape or whatever. ....and if my supposition is incorrect, I know I'll be corrected very shortly!
But, seriously, think of it this way: If you are the CF Martin company, that headstock shape is iconic. Yet, it isn't going to work very well with post tuners. What do you do? I guess you do what they did.
PostPosted: Sat Jan 03, 2015 7:57 pm
First name: D
Last Name: S
Nice Joe!
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Jan 03, 2015 8:17 pm
Last Name: Beaver
City: Lake Forest
Thanks CP and Dan. It is a pretty common alternative to the martin style.
CP...I think you may be right about them keeping the head shape when they transitioned from slotted to through the peg head. At least it sounds likely to me.
It's a lot easier to just move a couple holes then change the head stock and have to hope it catches on.
Joe Beaver
Maker of Sawdust
PostPosted: Sat Jan 03, 2015 9:41 pm
You will notice the same thing on a Collings guitar with the similar shaped headstock.
These users thanked the author Don Williams for the post: Michaeldc (Sat Jan 03, 2015 10:14 pm)
PostPosted: Sun Jan 04, 2015 4:40 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
Well, Yes, Don it seems that you are right.
When you look at Mr Collings copying Mr Martin or Mr Gibson, I know which I prefer.
PostPosted: Sun Jan 04, 2015 8:56 am
First name: David
Last Name: Ferraro
City: Franklin
State: Pennsylvania
I love the Collings "dinged" headstock. I wonder if there's a story behind that design?
PostPosted: Mon Jan 05, 2015 9:49 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
Yeah, the Collings "haircut" peg head is a nice variation on the Gibson design. I love how the top edge is cut at an angle like a mandolin or banjo.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Tue Jan 06, 2015 12:15 pm
Strings touching have always driven me crazy too even though there are many many fine examples of beautiful guitars that exhibit said feature. I like the way Martin solved this problem that way they get to keep a nice light headstock. It's along the same lines as when the strings touch the exit ramps of a slot head, drives me nuts. On the Selmer guitar I built this happens and I have yet to get around to fixing it but I will, some day. In the future that will be remedied. But again, when my DjangoBooks news letter comes in I always take a look at all these beautiful new and old Selmer guitars and many of them have strings bent over the ramps.
A nit picking bunch we are aren't we.
These users thanked the author jfmckenna for the post: Michaeldc (Tue Jan 06, 2015 4:22 pm)
PostPosted: Tue Jan 06, 2015 2:49 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
On UMGF, the question was asked if strip tuners were a good option on a CEO-7, which has a standard Martin solid headstock. After I explained that the holes were not in a straight line, another poster came back and suggested that the strip tuners should work fine. Not unless you own a hole mover :oops:
PostPosted: Thu Jan 08, 2015 9:16 pm
Stew-mac will have one of those hole-mover tools in their next catalog.
PostPosted: Sat Jan 10, 2015 9:35 pm
First name: kurt
Last Name: thomas
City: colden
State: ny
Zip/Postal Code: 14033
I need one of those as soon as they come out, hoping that they include the hole reducer function in it as well and don't get greedy by offering it as a separate tool. Because, you know, sometimes the hole is in the right place, it just needs to be 1/2" and not the 5/8" you mistakenly drilled.
_____________________________
Kurt Thomas
"There's a first time for everything even if you do it by mistake."
These users thanked the author KThomas for the post: Michaeldc (Sat Jan 10, 2015 10:00 pm)
PostPosted: Sun Jan 11, 2015 11:48 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
On page 43 of their latest catalog that just arrived there is a selection of holes. They also offer a bag-'o-holes that must have overstocks and sizes that don't sell well.
Ed
These users thanked the author Ruby50 for the post: Michaeldc (Sun Jan 11, 2015 12:18 pm)
PostPosted: Mon Jan 12, 2015 10:57 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I don't think it is because the holes aren't selling well, they just have a surplus. The holes are a byproduct of their drilling operations and they are, wisely, making them available to market. Just look at the success Tony is having selling his BWR kerfs (hopefully he will send me a bucket full for the free advertizing).
If you are looking for a good source of holes, buddy up with archtop makers. They often drill a bunch of holes in the plates to get close to thickness. They just end up carving/planing the holes away. They get swept up into the garbage. If you offer to take them off their hands, everyone wins. . .
Bryan Bear PMoMC
Users browsing this forum: Bing [Bot] and 22 guests
